1 - 18 of 18 Posts
Some pcs of my Zuma.
I have the 70cc big bore kit, 19 mm carb, aftermarket tires, aftermarket variator with my own custom weights I made. I couldnt get any off the shelf weights to give my zuma any mid to top end range. Kevlar belt and All the aftermarket stuff needed to keep it going.
Discussion Starter · #2 ·
Oh, both my scooters
Welcome to the forum QuickMick , nice toys you have. I could sure use one of those it would save me plenty on gas.
Cool scooter. Probably would be a pain to haul my fat a$$ around town, that's why I had to step up to the 6. Do you need a license to ride that thing around on the streets?
Thanks. I will post a pic of my 2 stroke blender I made in a bit.
Im 220 lbs 6'2" and it pulls me good.
Discussion Starter · #7 ·
nice! looks like it gets up to speed pretty quick
Thanks, it does for a scooter.
Notice the blue one does not have rear turn signals that you can see. I did away with the stockers and incorporated it in the rear tail light lense.
I can post pics of this later, It was a easy mod that makes it look much better. I stopped there and havent done any cosmetic mods to it sense.
Discussion Starter · #10 ·
Are your Zuma's liquid cooled like the 125's
Nope all air cooled. There is a kit out on the market for water cooling it like the RS50 Aprilla's. Mine runs fine without it.
Discussion Starter · #12 ·
Yep, espically when you pull up to a car and make a pass.
Right now I need to buy another starter, Im having to kick start my Zuma because bumping up the compression has killed my stock starter.
Hi all my name is brandon and I personally run an orange (repainted from blue) zuma with an 70cc athena aluminum cylinder with a tecnigas pipe (really wanted the stage 6 1200 but cant afford 1000 more to fully convert to watercooled plus with the noise my neighbors would kill me.), an over rev variator and a 24mm mikuni carb that tops at 60-65. :whoop:
Id love to upload pics but for the life of me I cant get them to upload :confused:
1 - 18 of 18 Posts
