Yamaha mt 125 ,Stop when being ride. Won't start again, Got new plug ,fuel pump and injector check all working. Battery is fine. Air filter is new. Engine turns over. Just won't fire up and run.
Then next if fuel. Even with new pump it might not be working right. Spray some starter fluid, brake cleaner or carb cleaner into air inlet. Does it try to start or at least pop some. If so, you have a fuel issue. Post back results.
