Yamaha fz8 misfire/poor idle.
263 Views 2 Replies 2 Participants Last post by  Rysrys z800
Hi, long story cut short. Bike runs fine open throttle but tick over and v low revs had intermittent judder or misfire. Was checking coils and 3 are the same and 1 is different. All.test ok but seems shorter. Will attach pic. Does this seem normal as I'm no expert at all but seems to be maybe a bad connection. Thanks all
Camera accessory Liquid Cylinder Gas Electric blue
See less See more
Hi, long story cut short. Bike runs fine open throttle but tick over and v low revs had intermittent judder or misfire. Was checking coils and 3 are the same and 1 is different. All.test ok but seems shorter. Will attach pic. Does this seem normal as I'm no expert at all but seems to be maybe a bad connection. Thanks all View attachment 2960
I would suspect the spark plugs first.
Also, you could check the holes in the head where the plugs are for the depth of the odd ball. just use a screw driver or something and mark the depth of each hole to find the short one to be sure you get them back correctly.
Yes! Spark plug gap was wrong on 2 of them!! Perfect now 😀
  • Like
Reactions: 2
