What year are we talking about? Are you able to get your hands on a service manual? It will have the correct procedure to disassemble. It will also have specs to check for serviceability & the correct torque spoecs for reassembly.
Ah. OK so it’s just a friction fit? No fasteners at all.There should be pry points(edges that over hang the gear case) on either side of the base of it. It has a sleeve with a couple of o-rings so it’s a bit of a tight fit coming out but it will go. Just work it back and forth carefully with a small pry bar
thats a huge help, THANK YOU!My bad it’s one big fat o-ring not two. View attachment 2865
No problem happy to helpAh. OK so it’s just a friction fit? No fasteners at all.
BINGO!No problem happy to help
10-4 Thanks againNo that sounds normal. You’re just hearing the forward and reverse gears meshing with the pinion gear on the end of the drive shaft. It will sound a little louder when there is no gear case oil in the lower unit also
