I own a 2006 yzf 450. I was wandering if anyone knew why i have no top end. strong bottom end. Timing been done. jetted right.
What kind of mods are on it. Sproket could be the problem. Lots of pipes are tuned for low end grunt instead of high end power and that could make a big difference. Cams would be the same way. Just all in the tunning if it's not stock.
are you tlakin bout yfz quad or yzf bike....on a yfz quad as long as you have 20" tires you should still have top end with any pipe...check the clutch plates
