Hi all.. noob here.
Did a oil change first time, and did two mistakes, how to correct the same.
1. Over filled the oil, is max now. Should I drain it a bit?
2. I forgot to change the filter , Can I change the filter without draining the oil first?
Hi all.. noob here.
Is it a screw on filter? if so go for it. Yes, make sure there is not too much oil in it, drain if you have to.
