· Registered
My rhino 660 won't start sylonod just clicks I ran a hot wire from battery an tap it off starter nut but it doesn't click bump over or nothing help would be greatly appreciated I've checked all wires an grounds is the starter just locked up
· Administrator "Loose Nut" - From Bandera, Texas
Just bought it brand new
New battery doesn't mean it's fully charged or good. When starting diagnostic work, I always start with the basis. If battery test good, then next thing to check is negative battery cable, not the battery end, the bike end. Corrosion there is infamous for causing electrical issues. Then check for full battery voltage at solenoid, if not back track and fix issue. Then check starter side of solenoid, full power voltage with starter button pushed. After you have completed these test, report battery voltage at the terminals, we can then diagnose further.
