Hi
I've got a wr125x 2013 and could really do with some experienced advice please? The bike's last 2 MOTs have had an advisory for "lower rear shock bush" . I've been searching for far to long now and 3rd MOTs in January.
So far as I can tell it seems to be the connecting rod bushes as apposed to the actual shock. Which I've found is basically 2 metal tubes and 2 oil seals each end.
I've got the part numbers for the bits
#6 bush - 90386-18004
#7 oil seal (2J5) - 93109-18020
#8 collar - 90387-12X01
But this is where the problem comes in. Every time I've found the parts listed it always says the #8 collar is discontinued.
so I don't know how to sort the issue out.
have they done away with that in favour of a better design? I have seen a lot of universal suspension bushes for sale so have wondered if that's an option. If so what dimensions would I need to do both ends of the connecting rod?
PLease help,
Thanks,
Steve
Administrator "Loose Nut" - From Bandera, Texas
What's a MOT .?
Think of it as your state inspection on steroids. They check everything, and I mean everything. Everything must be correct. You are from Texas like me, and our inspection is almost a joke compared to a true MOT.
Land vehicle Vehicle Wheel Tire Motorcycle
Google what all is checked. If they were to do it here, 90 percent of bikes would fail.
