Recently purchased a 2003 R1 w/power commander 3. I was told the bike had sat for a few years. I replaced fuel pump and drained fuel changed oil etc. only to find out I also had no spark. I followed the troubleshooting manual and got no where. Here is where I am a little confused. I am getting over 12 volts at the head of the harness on the hot wire when the key is on and kill switch is on. I was under the impression the second wire is a ground wire? But if I connect a light probe tester to the positive on battery and to the second wire I get nothing doesn’t matter if bike is cranking or etc. I also get no volts or anything coming from the wire either. I check tolerances on the coil packs and they are right in the middle of the range. I insert the spark plug into the boot and ground the plug out and I get nothing when cranking on any of the coil packs. Could anyone clarify to me what the second wire is? I thought it was a ground but the plug is also grounded to the engine when threaded so I’m not sure. Appreciate any help. *spark plugs are brand new*
