Maybe check the intake joint at the carb? Sounds like it could be getting too much air and you’re having to counter it with more throttle to keep it going. You can try (carefully) spraying some brake clean around the carb joint while its running and see if the idle/running condition changes drastically then you’ll know it’s has a vacuum leak causing a lean running condition.
