· Registered
Hello, I have a 1989 Yamaha Big Bear 350. I'm having an issue with the reverse shifter. It shifts into reverse just fine, the problem is getting out of reverse into hi or low, it requires a little violence. What could be cause this? Thanks!
· Registered
Way too many to list....
Welcome to the forum ... Try adjusting the idle speed .. lower .....Also a little lube on the linkage might help ... And , ... Welcome to the forum .. Tell us more about , You ,.. your bikes , where you ride .....
