Hey guys,
I am restoring and rebuilding a 83 Yamaha virago 750. I am come to the point of disassembling, the rear swing arm from the centre stand and frame, and as many of you probably know Yamaha did not have a grease fitting to be able to lubricate the swingarm shaft bolt. As a result, many viragos around the world after 2 decades of not restoring/lubricating this bolt and bushing fused and rusted together. In many cases heating these parts still do not do it and ultimately the bolt needs to be cut on each side of the swing arm to remove the inner bushing race and the bolt fused inside. Yamaha does not make this both anymore however, they do make every single other part in the diagram.
Does anyone have an old swing-arm with this bolt and willing to sell? Or does anyone know the dimensions of this both so that if I cut it, I can get it remade locally. Or is there any other way of solving this after cutting off the OEM bolt with another bolt?
What anyone else done?
Attached is the diagram that I’m dealing with and the both is labeled as #6.
