I picked up the ski couple of days back. When launched on the water I found that the sound system cannot be switched on, the power and usb outlets are not working. Also the light in the compartment (blue from the outlets) is not working.
I checked the fuses in the main fuse block. They are all fine but I'm not sure what they are for as the user manual does not have any mention of fuse block.
Am I doing something wrong, is there a trick to this or it is just plain not put together correctly...
Thanks in advance.
PS. I called the dealer and they said to bring it in but before I do I wanted to check out if anyone has come across this issue or knows how to troubleshoot it.
Thanks in advance.
