Have changed everything with working parts from another ski including
Throttle Position Sensor
Map Sensor
Throttle Body
Makes no difference
Replaced fuel pump and regulator
New plugs, oil
Checked oil level
Makes no difference
Had impeller checked, wear ring checked - gap and wear is within recommended margin
Ski runs perfectly on hose, flys on flat water once it is planning, good top end
Put 2 people on it, turn hard, put the engine under load - it gives you nothing back. Initial acceleration from a standing start feels gutless.
No balls, gutless, no grunt down low and yep I realise the VX was built for the rental market in the states, but I have driven many others that don't have this issue.
"No load on the engine with the impeller out of the water. Same as you running up hill or running on level ground. Need more energy/power to go up hill for the same speed." - it's not getting the extra "power"
If I change ECU will it give me a better result? Or was this model VX 2013 - gutless, did they bring in pollution control or change anything for this model?
Out of ideas
Yep buy an 1800 - I hear ya
Map Sensor
Throttle Body
Makes no difference
New plugs, oil
Checked oil level
Makes no difference
Out of ideas
