I bought a 2011 Grizzly 450 on the cheap knowing it would probably need engine work. It had been sitting a while so I put a new carb on it and cleaned the rest of the fuel system, changed the oil and filter, checked compression, checked the coolant and cooling fan operation, all looked good and I was able to get it running to hear it and do any further diagnosis of potential issues. As soon as I got it running I could hear a definite, loud ticking. I'm thinking it could be a connecting rod bearing because the top end looks good and compression is good, but want to get some opinions here. I couldn't attach the video so you can check it out at the link here, you can hear the noise pretty clearly: IMG_5109.MOV
When I drained the oil I didn't find any evidence of internal damage, oil was dirty but not metallic and no chunks, etc. I'm trying to think of anything else it could be but can't come up with any other ideas, valves maybe?. I am also wondering if it's possible to get an inspection camera into the crank case to verify an issue with the crank or connecting rod before I pull the engine? Thank you for any input!
