1 - 10 of 10 Posts
Hey guys,
I'm not getting spark on the output side of my coils on cylinder 2 and 4. I replaced the coils but the problems persist. I'm seeing power on the input side of the coils with an inductive timing light but not output.
I am waiting on an adapter to read peak input voltage but if it's irregular on those two cylinders what should I be looking into?
Thanks ahead of time yall!
I went ahead and cleaned up the grounds on those two coils and the common grounds for the harness on the back of the block. I saw no change; as far as having enough current to light a timing light.
I do see current after the bullet connector on the input side of each coil, but until I get the peak voltage adapter in the mail I only have a theory that I'm not getting enough juice to light the coil.
Way too many to list....
Are you using a proper spark tester ?
1 - 10 of 10 Posts
