Need help. How do I remove the bezel. Trying to convert from 3 pin to 2 pin.
Grover · Registered Joined 18 d ago · 3 Posts Discussion Starter · #1 · 17 d ago Only show this user Need help. How do I remove the bezel. Trying to convert from 3 pin to 2 pin.
Lesblank · Administrator "Loose Nut" - From Houston, Texas Joined May 13, 2021 · 308 Posts #2 · 17 d ago Only show this user Need to push center section in, then gently lift up on rim, a small flat blade screw driver normally works well.
Grover · Registered Joined 18 d ago · 3 Posts Discussion Starter · #3 · 17 d ago Only show this user Lesblank said: Need to push center section in, then gently lift up on rim, a small flat blade screw driver normally works well. View attachment 2317 Click to expand... Thank you. Got them out. Unfortunately one broke so I guess Monday I will be looking for replacement.
Grover · Registered Joined 18 d ago · 3 Posts Discussion Starter · #4 · 16 d ago Only show this user Dumb on me. When I went back to put the old plastic rivets in I realized they were a one time use rivet. Duh.
