I have a 1991 Yamaha big bear 350 4x4. Problem I am having is, is that replaced the centrifugal clutch with a factory Yamaha clutch and also got the tusk clutch and friction plates. So everything is all new. I put it back together and not it jumps worse that it did before. Also to if you shift into first gear and hold it up it tries to run away, when held up it should be in a neutral of a sort. From what I can figure the shift cam and the arm that's supposed to depress the clutch basket is not working properly. Any ideas what's going on
